I need to see(show) local value (stress). I need function like Probe. How to do it ?
Solved by raviburla. Go to Solution.
Hi RadoG,
In order to probe for results, you will need to use the "Query Display" command. Here is how to do it:
1. Activate the result that you want to display.
2. Right Click on Mesh Model->Total Nodes browser tree and choose Query Display.
3. Once this command is active, choose any node on the model to show the result.
Attaching an example image. Please let us know if you have more questions.
Ravi Burla (Autodesk)
Is there any way to filter data in probe label?
For example, i need only numerical value inside probe label. I do not need "Element XXXX, SOLID VON MISES...." text,etc.
P.S. I am using Nastran In CAD 2018
Your suggestion would be good for the Ideas page.
Hi @John_Holtz
Thanks for reply!
I will suggest it to Ideas!
