Hi
I have problem with Nastran-In-CAD. When I use beam generator in assembly, and choose beams to add them in physical property, everything's work, but then I can't mesh, cos beams are not saved in the physical property. Other option also don't works (constraints, loads).
I use Nastran-In-CAD ver.10.2.2.425
Solved by AndrewSears. Go to Solution.
Can you please share a simple model related to this issue.
Thanks!
This is a known issue and we are working on the solution. The workaround is to close the assembly and everything will work once you open the assembly again.
Keep the comments coming!
Andy
