MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
Timewarp curve on entire story
4 REPLIES 4
dre4mer12345
431 Views, 4 Replies
Hi guys,
I have seen that you can use time warp on individual clips in story. But I'd like to be able to retime via Fcurve the entire story with ALL characters. Is this possible? I tried plotting the entire story to a take, which I thought would work but then I have to select ALL keys for 22 characters which basically grinds MB to a halt and it's nearly impossible to try and work with timing and keys at that point.
Thanks for any assistance!
-Ethan
4 REPLIES 4
dre4mer12345
in reply to: dre4mer12345
Anyone have any insight on this?
3dMastermind
Unfortunately, it doesn't seem possible.
Manny Papamanos
StingRay | MotionBuilder | Maya | Mudbox
Games QA Specialist
dre4mer12345
in reply to: 3dMastermind
Yeah after alot of searching I seems that is the case. A sort of work around is to bake the whole story out to 72 fps. Render it at 72 FPS and then time map it in after effects. That's what i'll have to do.
A timewarp curve can be created once and reused. The way you could do this in Motionbuilder is apply it to a few characters at a time, plot them and batch them in chunks instead of trying to put one curve over all 22 at the same time.
