I am trying to export an FBX animation that I have through Motionbuilder.
All my FBX nodes have spaces on their names. When I try to export my animation into BVH format, I get the message I mentioned: "Spaces are not allowed in BVH node".
And then Motionbuilder lists all my nodes. But it does not offer an option to correct the names for exporting purposes. Let's say, for example, replace the spaces with underscores.
How can I automate this in Motionbuilder? I need to change the name of all my nodes, and I have plenty of them. I just need to do it, so I can export.
Solved by s. Go to Solution.
for renaming I can propose you to use a renamer script from here - https://github.com/Neill3d/MoBu/tree/master/PythonScripts/SceneManagment
