Dear all
I running into trouble with my motionbuilder 2014 today as i updated my nvidia driver version from 304 to 331. Im on linux by the way...
Mudbox is starting with the splash screen, loads some libs and crash back to desktop with no bash echo or something else:
No Qt_GRAPHICSSYSTEM environment variable set, "raster" used as default. MotionBuilder compiled against Qt 4.8.2, runtime linked to Qt 4.8.2 Status: Using GLEW 1.5.3 Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolconstraint.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libnetwork.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolshaders.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolbrowsing.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolnle.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libfbxmb.so MotionBuilder compiled against FBXSDK 2014.0.1 Release (0) Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolqttest.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtooltimelinex.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtooltrigger.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolanimation.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtooldebug.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libDynamicLightingInternal.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libmidi.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libdeck.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libsound.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libbasic.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libmagnetic.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolweighting.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libscript.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtooldevice.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolcharacter.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libgpi.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libfbmcs3800.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libspaceball.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolpythonide.so KPythonServer: Listening on port XXXX... KPythonServer: Serving on 1 address. Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libhikhost2013.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolbroadcast.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtrigger.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libglove.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtooloptical.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtooldesktop.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libkcuda.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolprofiling.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolmanipulator.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libPhysicsConstraint.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolfacial.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolmedia.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libvoice.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libhikhost2014.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolfcurve.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libkvectorgraphics.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/libtoolpropertybrowser.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/PhysicsEngine/libEngine_PhysX.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/extensions/PhysicsEngine/libEngine_ODE.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/plugins/libkrtfilter.so Load Library: /usr/autodesk/MotionBuilder2014/bin/linux_64/plugins/libperforce.so
After the last entry Motionbuilder crash back to desktop without any other hints...
If there is some option like in maya (MAYA_DEBUG_ENABLE_CRASH_REPORTING=1) to debug the startup, let me know and i'll try it with debugging enabled.
Any hints will be welcome 🙂
I can agree with that (tested), but shouldnt there another solution as well? What has so dramatically changed from 325 to 331?
3.11 kernel with NVIDIA 331.38 works.
From Phoronix back in Nov 2013:
NVIDIA's driver needs to be able to determin that all allocatable memory to the driver can be accessed by the GPU, but with this 3.11 change, that's no longer easily possible for determining the highest allocatable system memory address. NVIDIA is working on a proper solution but for now they've published a patch and are working on integrating this workaround into upcoming driver releases.
