MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
Constant time delay via constraint or scripting
2 REPLIES 2
585 Views, 2 Replies
I was wondering wether it is possible to introduce a time delay to real time input, e.g. a rotation, a vector or a number.
I saw some delays in the relation constraints but as far as I understood these are only fitting for a single number and not for continous input ?
Maybe some of you have a better overview on the possibilites, im new to constraints.
2 REPLIES 2
doodski
relation constraints are direct connections so if you connect one object to another it will follow real-time. you might delay that connection by interrupting the stream (putting a delay/time type node) in between the driver and receiver.
I don't know which nodes will achieve your results.. probably time and a subtract or multiplier type function.
Pull is supposed to allow for a time delay but it seems to have a bug.
