There use to be a way to append fbx files... basically to make animations longer by adding takes. The way one would do this was to click append as opposed to merge. This is no longer an option. Is there still a way to merge without overriding?
thanks
Hi chweintr,
If you want to append an fbx file to an actual scene, you can do the following:
1. File > Merge... > Select the file and open it.
2. In the 'Merge Options' dialog, if you right click on the icon beside one of the Scene element (e.g. Actors), you can see the following menu items:
- Append All Elements
- Merge All Elements
- Discard All Elements
If you select "Append All Elements", you will get your desired behavior.
Best regards,
Francis
