Hello!
I've worked with Motionbuilder for years but recently I've had to look at facial mocap and I'm having a spot of bother and wonder if anyone could help please. Basically, I've completed the marker set list, checked Regions under Display and Active under Rest Pose but when I play the take the face in the
Mocap Preview window tears up.
The areas recieving data, namely the nose, mouth, chin, cheeks and eyebrows pull away from the face leaving the bulk of the head behind. Does anyone know why this might be please?
I'm using Motionbuilder 7.5 Extension 1. The data is a sample I found on the web. It's a C3D file and the only thing about it is that it isn't facing into positive z but I rotated the optical root and thought I might be able to get away with that.
Any help would be greatly apprechiated!
Thank you!
