I have been working as Tool designer since last 2 years.Now i have interested in moldflow. Could anyone suggest me What are the things i should study, In which way i should go?
it will be really helpful for me. I am looking forward on your reply
Pradeep
Mold Designer
pradeep8491@gmail.com
Solved by madhukeshwart. Go to Solution.
Hello pradeep,
I suggest you to learn Moldflow insight. It's result are pretty good when you input exact values. You can study fill, pack , wrap and many more in this software but fill, pack and wrap are major. You can find many facts from simulation result fill time, fill pattern, temperature at flowfront, clampforce of IMM, air traps, weld liines, sink mark, deflection of the part after shrinkage and many more.
Regards
Sanjay Paul
refer the following weblink
http://www.ascented.com/courseware-solutions/autodesk/courseware/autodesk-moldflow
List of 2017 manuals are available. You can be master in Moldflow for sure being a Tool designer
Hello sir,
I will go in this manner.Thank you so much sir.
Pradeep
