Hello
I have problem with shrinkage compensation. A part with material Ticona Hostaform C9021, that its shrinkage in data sheet is 2% for parallel and 1.8% for perpendicular and dimensions are 170*60*2 mm and its geometry is attached, I meshed in MD and DD and 3D. With same process setting condition, followed by molding window analysis. I ran Fill+ Pack+ Warpage for MD, DD,3D and Fill+ Pack+ Shrinkage for MD and DD. Finally, the result about shrinkage compensation was confusing.
Based on fill+ pack +warpage and applying various pack profiles, the average value of shrinkage compensation is:
| Shrinkage compensation | ||
| X | Y | Z |
MD | 2.047 | 2.046 | 2.022 |
DD | 2.062 | 2.3 | 2.084 |
3D | 1.012 | 1.084 | 0.953 |
And based on fill+ pack+ shrinkage , the recommended shrinkage allowance is:
Total = 1.97 +/- 0.11 %
| recommended shrinkage allowance | ||||
| X | Y | Z | Total | |
MD | Recommended | 2.01 | 1.93 | 0 | 1.97 |
Single Value Validity Range (Max. -Min) | 1.86:2.15 | 1.75:2.11 | -0.00:0.00 | 1.82:2.11 | |
DD | Recommended | 2.01 | 1.92 | 0 | 1.97 |
Single Value Validity Range (Max. -Min) | 1.86:2.15 | 1.74:2.11 | -0.00:0.00 | 1.82:2.11 |
I have some questions:
Specially in 3D mesh and DD for Y direction, Do they have to be equal or at least close together ?
Thank you
