Hi, i'm new to 3ds max, currently i use 3ds max 2015 sp2. My problem is when i create spline, and i snap it to grid, i cant see the segment which is seem to be overlaped by the grid line. This is the picture:
View grid is turn off
View grid is turn on, i cant see the segment.
Pls help me, thank you!
Solved by Steve_Curley. Go to Solution.
Hi, i have set up like what u said. But the issue still there. This problem didn't happen with me when i use 3ds max 2014 with default nutrious viewport drivers.
thank u so much, it works. when i changed to D3D, i can see the spline but not clearly, but it's ok.
