Hello everyone,
I am trying to build a large mansion (Size: 80m, 300m, 50m), but because it's very large, I find it very difficult to do it. Do You guys change system units when You build large structures?
Solved by Steve_Curley. Go to Solution.
I might go with Feet with decimal inches for that particular kind of modeling. That should allow for smaller details, while still giving you large enough measurements to accurately scale walls and room layouts. Up to you, but Meters would be too large, as mentioned, and I think mm or cm might be too small. I don't know of many rooms measured in mm, although you can do the math to convert feet to mm pretty easily. All depends on what you are modeling, and how accurate you need your grid snaps.
