Hi all,
the task is simple but I simply do not know how to solve this problem
I have an object made out of two thin walls, these walls need to be filled to create a solid.
How can I do this? in 3ds max?
Or is there a possiility to export the file in such a way that the gap is filled?
more detail: immagine its a beer glass made out of two thin walls.
Hi, well I understand what you mean and ill test it right away. Just to clarify even more, is that I want to export the 3ds max file to a STL file to be printed with a 3d printer. IF the STL file contains two infinite thin walls, the printer will not lay any lines. Ill post a screenshot what i mean. The red circle indicates the hollow glass which needs to be 'filled'
Alright, I tried and found some errors that I managed to fix.
Now there still remains the problem that the objects remains hollow.
Is there a possibility that someone can look at the object which helps visiualising the problem?
The thing is that I spend alot and alot of hours in this object and now it seems there is no way of exporting or filling up this hollow surface for 3d printing purposes?
The helix and stairs were also not printed by the STL printer...
It is NOT my intention to dump my file here and let someone else solve it, just desperate that I cannot find the solution and hoping there is a solution here that someone can see within the file mayby?
Best regards,
Bas
The 3D printer we are using is a STL printer Stereo Lithographic (liquid). The size in 3dsmax does not matter as the 3D printer software can scale the STL file with a push on a button.
With the first model as it is now, we first did a test run and figured out that not only the walls were to thin (maby due to the letter 'a'), but also the helix and stairs were missing in the final print
