Hi everyone. I'm hoping someone might have some insight into an issue that seems to rear its ugly head every couple weeks or so for me. It's affected me in both Maya 2013 and now LT 2015.
The issue happens when rotating any random piece of geometry I've modeled, in this case a window border. The object will be fine when scaling or translating, but no matter what settings I seem to have on for rotation or how many times I delete the history, it skews when I rotate it.
Example:
Pre-rotation geometry
After rotation
In this particular case, I'm trying to discretely rotate at 15 degree steps. That seems irrelevant though since unchecking discrete and free rotating causes the problem, too.
Taking the same piece of geometry into a brand new file will let me rotate it without issue unless the rest of the model within the scene is also pasted into it. Copying and pasting it back into the problematic scene after rotating in a new file results in a correctly rotated model but will then go to skewing when rotating if a new rotation is applied.
Does anyone know what causes this, or better yet how to fix it permanently so it doesn't happen?
For reference, I am running on...
Nvidia GeForce GTX 460 graphics card.
I realize this is an old post - did you figure out what was going on? I wonder if your geometry has been parented to another piece of geometry instead of grouped; depending on that hierarchical relationship and how it may have been unparented, you might get a transformation error like the one you see.
