Hi, I have a problem where when i use the left click key to rotate around an object like normal it rotates in a weird way. how do i reset the controls back to the defaults.
Thank you
You're basically pivoting the camera around a point, which by default is at the center of the grid. If you want to pivot around an object, select the object and press the "f" key, to frame the object in the camera view. This will set the rotation pivot at the center of the object.
