Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Need help with Maya 2012 - attach surfaces please
4 REPLIES 4
353 Views, 4 Replies
Guys
I am completely baffled with this - so i have a surface lofted from ep curves and i duplicated this - now i am trying to attach the two surfaces and am getting a 'pinched' surface. I have been trying to figure this out for the past three days but am completely stuck - if you can please help me out i will be in your debt.
Attaching pics.
Thanks so much !!!!!
Gerry
4 REPLIES 4
Done.
I am picking up Maya on my new assignment - so please forgive my ignorance - this is day 15 of learning.
I think i know what was happening so i had one curve - duplicated it to make it bigger (same parametrization) then lofted. Whilst doing all this i had to detach the surfaces also to make room for the engine. So there were several detachments. Somehow some isoparms got messed up leading to the pinched look. So i had to redo from scratch. Other alternatives i looked at wold be to rebuild surfaces output to polygon and mesh or attach in subdiv. But i really wanted to attach in Nurbs.
Perhaps this is pure ignorance - so please forgive me if i am missing something very obvious - please post to this thread if you know the reason for the pinch.
So results are attached 🙂
I love Maya.
One important note about Maya - never give up. This is after 3 days - was stuck on one problem. Perhaps one day i will look back at this post and be like 'whaaaa i was dumb!!!' 🙂
n8skow
I suspect you duplicated your original curve (for the 2nd curve) and mirrored it?
Try reversing the curve direction on your second profile curve before lofting the surface.
Hi i will try this - i will do this as soon as i get back to my appt - i never thought of this - i think you are right - BRILLIANT - i will check it out.
Tx
