3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Meshsmooth/Turbosmooth iterations
3 REPLIES 3
janiashvili
251 Views, 3 Replies
I've got one question, is there a way to change meshsmooth iterations based on camera distance?(e.g. far objects to have iteration 1, and close objects to have 10)
3 REPLIES 3
Steve_Curley
in reply to: janiashvili
http://area.autodesk.com/forum/t39473
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
janiashvili
in reply to: Steve_Curley
is there a way to make everything variable on such way, and on viewport(not on camera object)
Steve_Curley
What do you mean "make everything variable"? If you mean the distances then you would have to change the script and re-apply it. It can't be infinitely variable because it is controlling the iterations which are a set of constant values and therefore require discreet "steps" in the distances to trigger the changes.
As for the viewport - I have no idea how one would do that, if it's even possible.
Max 2016 (SP1/EXT1)
