Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Insert edge loop, L mouse button for relative, M for absolute?
1 REPLY 1
becoolmin
798 Views, 1 Reply
Hi there,
Is there any way to set shortcut to insert edge loop, one key with left mouse button for relative, right button for absolute?
For example, if I set N for insert edge loop, when I press N, maya turn on the insert edge loop tool.
I would like set left mouse button for relative edge loop that I can choose any where to insert edge loop.
And right mouse button for absolute that I can insert edge loop exactly in the middle.
Would it be possible?
1 REPLY 1
halfstone
in reply to: becoolmin
This is actually a function of the new multi-cut tool.  If you engage the tool and use <Ctrl> LMB, you will insert an edge loop in relative mode; <Ctrl>MMB for absolute (bisect the face).  <CTRL><SHIFT>MMB will allow you to snap the edge loop incrementally, based on the step size in the tool.
You can assign a hotkey to the multi-cut tool; go to Window->Settings and Preferences->Hotkey Editor and find the tool command.  If your chosen hotkey combination is already assigned to something else you can over-write it.
