I have been reading some posts on scale. If I were to construct a model in Sketchup with units set to Imperial should I scale the object to metric (I see that the default unit for Maya is 1 cm = 1 Maya unit) before importing? I was also reading that if the scale is off then it will cause problems with lighting and a few other things.
What would be the best scale factor before importing? Should I scale my SU model as: 1 cm = 1' or 1 cm = 3' or 1 cm = 5'? Or it doesn't really matter as long as I scale it in some way...
Thanks.
