Hi, I'm currently reading the online Maya tutorial book, and I'm on Polygonal modeling>Lesson 1: Modeling a polygonal mesh from a reference image>Selecting edge loops
For some reason, even while using the Snap to Grids feature, trying to move the edge loops won't straighten them out. I'm trying to turn this:
Into this:
I'm pretty sure that I've followed the instructions correctly, so what am I doing wrong?
Thank you,
James
Solved by _sebastian_f. Go to Solution.
Make sure you are in world space for the move tool (can be found in the move tool settings - double click the move tool), select the edge loop, hold down x to snap to grids, then move it.
