3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How to "connect" or bridge these edges?
1 REPLY 1
MbdeltaPC
1042 Views, 1 Reply
I rather new to 3ds Max and am working on a model in which I need to bridge the gap between two edges. However, the bridge tool doesn't seem to work for this. Here is what I'm trying to connect. http://i.imgur.com/eWVt1vG.png
Can anyone tell me how to get this to work?
Thank you,
-Mbdelta
1 REPLY 1
Steve_Curley
in reply to: MbdeltaPC
You won't be able to do that with the model as it is now. An Edge can only have 2 Polys attached to it - one either side. The right-hand edge you highlighted already has 2 polys attached to it, that's why Bridge won't work.
Select and Delete the Poly attached to the left side of that Edge, then you should be able to Bridge the gap.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
