Hello!
I have a house model from FBX file, it has several doors in it, but the doors are not separate so I cannot make it open in game.
Is there any method I can cut out the door make it separate and then make it open in the game?
Solved by blakestone. Go to Solution.
Thanks for the reply!
My house fbx model doesn't allow me to detach the door because the entire front house walls doors windows are one piece.
I can not detach this way, but there must be a method to cut out yes?
You can use Bones or Helpers combined with the Skin modifier to rig your model to allow specific parts, such as a door, to move. I have setup a very basic scene showing how this can be achieved. I have included the MAX file (requires 3ds Max 2011 or higher to open).
