3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
hair and Fur : Instance Node / Scale
3 REPLIES 3
1339 Views, 3 Replies
Im racking my brain trying to figure out why when I use the hair and fur modifier and I instance in a piece of geometry, it normalizes the scale. Does anyone know how to avoid having it do that? The geometry comes in tiny (it's not the scale, cut, random scale, root/tip thickness parameters ..
3 REPLIES 3
krueger_1
Did you scale your instance geometry at the object level? That might cause your H&F geometry to come in small if you scaled the instanced geometry up.
3ds Max 2009 SP1, 2010 SP1
Maya 2012
Windows 7 Professional 64-bit
Dual Intel Xeon E5520, 6 GB Ram
NVIDIA GeForce GTX 460 OC
Nope I just created it. I did taper it, but i collapsed and xform reset it.
krueger_1
Can you zip and post the scene noting which version of Max you're using?
Maya 2012
