Why is it I cannot set minimum distance smaller than 1.0?
I have a whole host of files containing very small objects at small scales that I need to use topology strips on, but cannot, due to the seemingly arbitrary minimum setting.
I turned on the macro recorder in an attempt to find that UI parameter so I could manually force it lower via script, but that parameter is invisible to it.
The whole ribbon thing is god awful. Please put those tools in the modifier panel or a floating dialog or something so I can turn off the ribbon forever.
