When I try to delete or do a save as of a polygon file I get the following message:
"The file being saved was created by a Student Version of Maya intended for personal learning only. If you save the file, this message will always appear whenever the file is opened."
What can I do to delete what I need to and then resave the file?
Thank you,
Andrew G
Solved by tsefreeflow. Go to Solution.
It is not an error, it is just the annoying thing Maya has for student versions of the program. It is better that popup than any watermarks or anything. It saves just fine, but this popup will show everytime this file is opened if created in a student version of Maya. Even if it is later opened with a full version.
BTW, You should delete your other post that is nearly identical to this one!
