Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
discplacement map problem
2 REPLIES 2
404 Views, 2 Replies
Hey , not too sure what is causing this?
any suggestions?
Also does anyone know if a displacement map gets exported with an .OBJ material file?
Ryan
2 REPLIES 2
Problem solved!
mental ray was running out of memory....so i lowered the mesh splitting factor and it rendered fine.
3dMastermind
Nice, however this would be a very costly way to make car tires in terms or rendering time and resources.
I would suggest this approach, worked well for me back when I made tires.
Use a deform on curve in the end.
http://forum.d4school.net/t407.html
For the sidewall data, a bumpmap should suffice.
Of course, if you just want to showcase tires, then that is a very good result.
Manny Papamanos
StingRay | MotionBuilder | Maya | Mudbox
Games QA Specialist
