3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Cap poly and Weld does not work?
2 REPLIES 2
2669 Views, 2 Replies
Hello
I'm trying to model glasses. I have completed the frame and the handle. They are different parts of the 3D object.
http://i56.tinypic.com/x4n9rn.png
Now I would like to connect them together. I tried to choose some vertixes and use cap poly tool to cap them. But it doesn't work:
http://i51.tinypic.com/2sako09.png
Then I tried to move those vertixes close to each other and use the weld tool but it doesn't work either.
I have had many problems connecting different objects together with cap poly and weld vertixes tools in the past and now I would like to know is this a bug or what I'm doing wrong?
2 REPLIES 2
hathMirx
Cap and Weld(not really ... Bridge) work just not how you might think they should.
Delete the end "cap" on the ear-piece tube (I know, it's not technically a tube it's solid alloy ..). Then in the same manner, after applying epoly to the lens frame and entering into face sub selection, delete the closest four quads; you leave another void in the frame oval structure like the one you just created at the end of the ear-piece.
Next, sub-select border (kidney-shaped icon under "Selection" of Editable Poly, after you've added this modifier to the stack of that piece. Making sure you've attached all the glass pieces so they're one entity and are able to see only one object in the scene explorer other than your head, Ctrl+ select both an ear-piece and a frame-hole.
Now, choose Bridge Settings (right beside the "Bridge" button) from "Edit Borders" in EPoly modifier, choose the settings you want to define the detail of the "weld"(sp). And the previously separate entities should now be entirely connected.
You could also NOT use Bridge and use Weld instead. But you've got to get rid of those caps either way.
Hi
Yes, bridge was the actual tool I was looking for but cap poly tool confused me 😛 Thanks for help 🙂
