3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Can't open .max file
5 REPLIES 5
Justin171267
2361 Views, 5 Replies
I'm trying to open a scene in 2013 but I get an error that the file was saved in a newer version of Max. Is there a way to open the scene?
Justin
5 REPLIES 5
Steve_Curley
in reply to: Justin171267
Not without access to a later version, then the scene could be saved as a 2013 compatible file. Ask whoever created the file do just that.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Justin171267
in reply to: Steve_Curley
I don't know who made the model. I downloaded it from CG site.
Steve_Curley
If it was free then zip it and attach it to a reply asking if someone would mind converting it for you. If it was paid for (obviously do not post it here) try contacting either the site or the author. Most such sites do state the Max requirements - you need to check them before downloading.
Max 2016 (SP1/EXT1)
You'll need a newer version of 3ds Max, or someone to convert it for you. Have you attempted to import it?
rfhoward8
I have many .max files created years ago with a scanner, and I downloaded a free trial version of autodesk 3ds max under the impression it would open these files. No luck importing or opening in the software. Suggestions? R
