Dear all,
It has happened me several times, that, the wireframe model got rendered in the worskpace incorrectly. I am not talking about quickrender, but about fast flat render of the model while modifying its geometry.
Please, take a close look at the attached image:
- You can see that the shaded mode has black maps. As I rotate the object, the blacsk maps jupm here and there over the model.
- I checked if normals are set properly, yes they are.
- I have restarted Softimate, but the problem appeared immediatelly, after loading the scene.
- When I create a new test box in the same scene, the box is rendered properly - there must be something wrong within the editing mesh.
- Is there any way to realign/reinitialize/refresh the mesh in the scene, so possible internal discrepancies can be fixed?
Have you had this experience please, an can you offer me soem directions how I coudl fix that?
Thanks many times.
