I am using 3DS Max 2015
I have two objects that are overlapping / intersecting. They are mirror images of each other of the exact same size and aligned on the exact same horizontal plane.
I would like to crop off the two extruding ends of the intersecting objects. I have tried all of the boolean and pro-boolean operations and none of them seem to apply to my situation.
Here is an example diagram
| o | | -+-----+----o-- | | + |
I would like to keep the object ends that have a + symbol, and truncate off the ends with the o symbol. My two objects are multi-curved objects so doing it by hand would be difficult.
What operation would I use?
Solved by Steve_Curley. Go to Solution.
I am making a bit of progress. I'm new to 3DS so I appreciate the help.
Attached is my progress so far. I have the corner section done. However I am not able to bridge / connect the gap between the two.
The edge curve of the corner section is the exact same as the curve of the side sections.
What would be the best way for me to join / bridge / connect the sections shown in my photo?
Thanks.
