Show only
Search instead for
Step: Invoke Insert command in mockup client and select file in 'From A360' Tab.
The files listed in your A360 account could be inserted in to Mockup, which Navisworks is able to read. Please upload the file to A360 account if you want to insert from A360
PS: For assembly file, pls Zip it with its reference files and rename the zip file as ‘assembly full name.suffix.zip’
Insert file from Local
Curerntly, only .step, .stp, .stl, .dwf, .dwfx, .nwd, .jt and .sat files are supported to insert from local
Insert file by addin in Inventor
Step: Open the file in Inventor and upload the file to mockup by Addin. So all 3D files could be uploaded to mockup, which Inventor is able to read
By the 3 ways above, the file can be loaded in Mockup, which Inventor and Navisworks are able to read.
