If you're using Inventor 2013 or 2014, don't forget to down the Mock-up Add-in. Check out our Quick Tip Video on leveraging the plug-in. https://www.youtube.com/watch?v=6bZOUIM6jSs
Good tip. How did you managed to install the add-in? I mean did you download the add-in? During the instalation I did not find any option. Also in add/remove programs there is no option to change/add just uninstall. Thanks
I found it easly. It is in the Autodesk Mock up start page at the bottom.
I see that you experienced an issue while trying to log into Mockup360.
can you tell us more about the workflow?
thanks,
Lucia
