Mockup 360 General Discussion
Join the Mockup 360 community discussions to get help and share technical knowledge.
Member
GNR88
Message 1 of 3 (493 Views)
Mockup 360 Application failed to run
493 Views, 2 Replies
07-17-2013 03:36 AM
Hi all,
I've having trouble getting mockup 360 to run. I double click the icon on the desktop, it says lauching aplication for a second then i get the splash screen for a moment then nothing.
I have tried installing from Firefox and Internet explorer and manually.
 Made sure my Virus scanner is off and windows fire wall, and user access control is off
I'm running Windows 8 64bit, Java is upto date 64bit version
Not sure what else to check? Or am I missing something obvious
Product Support
joel.palioca
Message 2 of 3 (484 Views)
Re: Mockup 360 Application failed to run
07-17-2013 09:28 AM in reply to: GNR88
Hi GNR88,
Could you try deleting the 3 files and the Mockup360 folder in the path below and relaunch the product?
%Userprofile%\AppData\Local\Autodesk\Web Services
Please let me know if this helps at all or if you still have issues and we can follow up to see how to resolve this problem.
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Member
GNR88
Message 3 of 3 (467 Views)
07-18-2013 02:24 AM in reply to: joel.palioca
I am now up and running
Thank you for your help!
If you need any more infomation to help stop this from happening to others let me know.
Maintenance Schedule and Server Status for Mockup 360
Autodesk now offers rental plans!
Autodesk is enhancing its software purchasing options by offering you the ability to buy monthly and quarterly rental plans. Rental plans give you access to a full-featured, commercial license of the Autodesk software of your choosing (excluding standalone software such as Autodesk 360). Interested in learning more? Find additional details here.
