Area :: Header
New tools, templates and workflows
Announcing Extension 2 for 3ds Max 2015 and 3ds Max Design 2015
Discussion Groups
MOCAP
Distinguished Contributor
jack4
Face capture and motionbuilder?
147 Views, 5 Replies
02-06-2009 08:31 PM
I am new to motionbuilder and have been doing some face capture test.
Is there a way to get the .c3d face capture data to apply directly on to character face with out having to do default character face pose set ups for it to reference the data to? I would Like to have it work like it does with body capture the data is directly applied to the rig. Is this possible? So far I am not seeing how this is possible.
Thanks in advance on any help with this.
Please use plain text.
Valued Contributor
_neill_
Re: Face capture and motionbuilder?
02-09-2009 12:10 PM in reply to: jack4
It's possible to connect mocap marker data to the character face... information on how to get it you can find in the doc's.
jack4
02-09-2009 06:29 PM in reply to: jack4
Thank you for the reply but it is just a little shy of any solid info. In the docs as you mention I only find the way to connect them is by using actor face and character face and this I am not having any issue at doing. I am seeing my character face being driven by the mocap datat but at the same time I am seeing it being altered by the character default pose set ups i have set up. I was just wondering if there was a way to get a direct link between the actor face info to the character face with out having to use the default face pose set ups that are then used. for instance so now if you only make a default small brow raise in character set up it will only go to this amount even though in the mocap datat it show a much greater eye brow raise.
Valued Contributor
_neill_
02-09-2009 08:54 PM in reply to: jack4
There is a way of creation some direct mocap data connection. Just create point constraints between markers and face clusters... also for this method you need to create some offset markers for control influence.
As I understand for this situation It would be enough if you create some blendshapes for the character and connect mocap actor to control blend shapes.
jack4
02-10-2009 12:29 AM in reply to: jack4
Ah ! of course! I will give this a try and let you know how it goes. Thank you for the advise.
New Member
damian22
03-18-2009 06:36 AM in reply to: jack4
Hi there.
Might I ask what motion capture system you are using? I am also trying to find a way to apply facial motion capture data to a 3D mesh in MB using constraints. It definately isn't easy (probably due to my lack of experience using MB).
Does anyone know of any links to example movies of rendered animation that was done using this method?
