Mechanical Desktop
Mechanical Desktop
0 Kudos
Post 1 of 7
Why does autosave turn off?
1001 Views, 6 Replies
10-08-2005 07:18 AM
It has happened at random, I notice that my Autosave, (set for 15min) is turned off and I have to go to options again and reset it. Has anyone ever ran into this & why? Using MDT6.
RIck Hamlin
*just havin a ball
Post 2 of 7
Re: Why does autosave turn off?
10-08-2005 04:34 PM in reply to: rdhdesign
> It has happened at random ...
Wonder if it's like the DIA sisters; CMD, FILE & ATT (if that was their names;
homely bunch anyway)? Gets toggled off by some function then you crash and it
has to be re-set manually?
_ _ _ _
The rest is just for fun...
Being as fond of inflammatory statements as any red blooded boy; if you have
intentions of moving on to a modern, parametric CAD system someday you might
want to wean yourself of the autosave function. That system probably won't have
one.
I normally don't use autosave with any app, but tried running it in MDT (tried
a few times with different versions up thru MDT6) and turned it back off because
I felt very strongly that it was Causing Random Crashes.
Valued Contributor
0 Kudos
Post 3 of 7
10-08-2005 05:57 PM in reply to: rdhdesign
I don't know your specific situation. Work off your hardrive and save to the server when needed. Working with a server
can cause a lot of unexpected crashes.
(just an old fashioned suggestion)
0 Kudos
Post 4 of 7
10-10-2005 07:23 AM in reply to: rdhdesign
Thanks for the reply guys. Thought maybe there was some others who had the problem. Can't find why it turns those "sisters" off.
I would switch to the better software if my customers would. I have already purchased new Inventor, & MDT, but can't save backward. Everything should be universal, but you know how that is.
Thanks again, anyway
Rick Hamlin
New Member
0 Kudos
Post 5 of 7
01-31-2012 09:02 AM in reply to: rdhdesign
I have had this problem for years, since AutoCAD 2004 (currently on 2011 MEP).  I go in to the options, turn it on and set it for 10 minutes.
A couple months later, when AutoCAD crashes, I go to my autosave folder, and the latest sv$ file is a month old.  Then I go to the options, and the automatic save function is unchecked again.  WFT?!
*Pro
118 Kudos
Post 6 of 7
02-01-2012 07:17 AM in reply to: Johnny_Kage
Could it be when Acad crashes, it forgets that option?
Window For Tournaments?
Please, not on this forum.
New Member
0 Kudos
Post 7 of 7
02-01-2012 07:33 AM in reply to: ampster
Don't be hatin' on Tournaments.  LOL, sorry.  That was supposed to be a ...
It's a plausable explanation, but it seems to stop doing that for a long time (months).  It happened to me yesterday, and the latest save was from November.
Edited by
Discussion_Admin
Manufacturing Community
