XP Pro SP2, Inventor Suite 2008, MTD 2008.
When I installed the programs, I selected the option for the materials library with the hundreds of professionally specified materials. When I do AMMASSPROP, I still get the same old 10 choices that have been available since MDT 2. Where is the new list of materials and how do I access it? Also the region/mass properties button on the INQUIRY toolbar from the AMDTACAD menu does not work. It gives a "no solids or regions selected" message dispite saying that select objects says 1 object found. The mass properites button on the PART MODELING tool bar works okay. There may be a bug because the command line for the inquiry button does not seem to be correct since it is massprop not ammassprop but there doesn't seem to be a way to change it.
