Mechanical Desktop
*Keller, Kent
Post 1 of 9
Where does my UCSicon keep going?
344 Views, 8 Replies
09-14-2000 12:45 PM
Anyone else finding their UCS icon disappearing on them? Seems like I keep
turning the display on and it keeps disappearing in different model
viewports.
Unfortunately I don't know what is causing them to disappear, but it is
getting old having to turn them back on.
Kent Keller
Strobe Data Inc.
www.strobedata.com
*Hinrichs, Dave
Post 2 of 9
Re: Where does my UCSicon keep going?
09-14-2000 02:02 PM in reply to: *Keller, Kent
I had several customers saying the same thing today.
Dave Hinrichs
Quannon CAD Systems
www.quannon.com
Kent Keller wrote in message
news:smileyvery-happy:1DF9F5D35C1E92BB4402C727C129C32@in.WebX.SaUCah8kaAW...
Active Contributor
0 Kudos
Post 3 of 9
09-14-2000 04:10 PM in reply to: *Keller, Kent
Hi Kent,
Seems like this could be a bug then or maybe not?!, I kept thinking it was just me. There didn't seem to be any
consistancy with it disappearing. I couldn't get it to repeat no matter what, all of a sudden it just disappeared.
I found it very annoying since I usually have the UCS on & at Origin.
Having siad that I seemed to be having a lot of trouble with other various things as well so I did a repair install from
the CD & everything seems ok now, including the UCS icon. Maybe this has fixed it maybe not, time will tell.
Cheers, Graham.
Active Contributor
0 Kudos
Post 4 of 9
Re:
09-14-2000 09:42 PM in reply to: *Keller, Kent
Hi Kent,
Well, surprise, surprise the repair re-install didn't work after all. Today the UCS Icon continues to disappear
as if by magic. I still can't get it to do it repeatedly, so I guess I'll just have to keep putting it bakc on!!
Cheers, Graham
*Keller, Kent
Post 5 of 9
Re:
09-14-2000 10:16 PM in reply to: *Keller, Kent
Well the only good thing about this is that I am not the only one seeing it.
It is one of those things you don't notice it missing until you need to know
which way is up
The things I would do that seemed to make it disappear more than normal was
shading, and unshading, and changing # of viewports, and activating different
parts. Not sure if it is directly related to any of those but I was doing a lot
of that today and they were disappearing every time I turned around. It seems
like it might have something to do with the ability to have different UCS's in
different viewports and or have the UCS icon on or off in different viewports.
Who knows ...just guessing.
It was really getting to me today, I am about ready to make a toolbutton or
maybe even a reactor to turn them back on every time I zoom or something
Kent Keller
Check out the Mechanical Desktop FAQ @
http://webhome.idirect.com/~dfulford/
"Graham" wrote in message
news:ef411c4.2@WebX.SaUCah8kaAW...
Hi Kent,
Cheers, Graham
Active Member
0 Kudos
Post 6 of 9
09-18-2000 03:53 PM in reply to: *Keller, Kent
I have had the same problem also.
*Austin, Kevin
Post 7 of 9
09-19-2000 09:54 AM in reply to: *Keller, Kent
Same thing here.
I never actually see it dissappear, but I'm always in shaded mode when I realize it.
I toggle shade mode on & off a lot while I'm working.
Kevin Austin
*Montague, Rhett
Post 8 of 9
Re:
09-20-2000 09:16 AM in reply to: *Keller, Kent
Same problem here. I always keep my UCS on Org. so it not being there
drives me nuts.
"Kevin Austin" wrote in message
news:0462FD91A0B5F0CBA4084520A8E29A02@in.WebX.SaUCah8kaAW...
> Same thing here.
realize it.
> Kevin Austin
Valued Contributor
0 Kudos
Post 9 of 9
Re: Re:
06-22-2011 05:03 PM in reply to: *Montague, Rhett
Windows 7 Pro SP1, AutoCAD MEP 2011, HP Z400 w/Dual ZR24w Monitors, 12G Ram........
My UCS was gone. I turned it off months ago because I was doing extensive 2D work.
When I tried to bring to back through the options dialoge it was persistent in staying away. I re-started AutoCAD, no luck
I kept getting the error message"Can not display UCS icon in 2D model space. Change UCS icon setting in Options dialog 3D Modeling tab."
I tried naming a view with no luck. I just went to work and ran a number of commands in 3D. It eventually re-appeared.?
Just thought folks might like to try it. It isn't a real solution.
Good luck,
Bill
Windows 7 Pro SP1, HP Z400 w/Dual ZR24w Monitors, 12G Ram, AutoCAD MEP 2012
Manufacturing Community
