Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
What's up with the new dimension scale in MDT6???
9 REPLIES 9
Message 1 of 10
522 Views, 9 Replies
Can someone please explain the rationale of MDT 6 forcing DIMSCALE to 1
when placing dimensions in drawing view?
For years I have used a dimension style that I use on all drawings, and I
set the overall scale for dimensions depending on the size of the drawing.
But now MDT6 always puts an override on dimscale to 1.
The solution, I have read, is to goto AMOPTIONS and set the layout scale.
This is a horible solution as it forces me to deal with layouts that are not
1:1.
Is the a way to tell MDT6 to use a specific dimscale other than by changing
the scale for the entire layout???
Muchos gracias,
- Jose
9 REPLIES 9
Message 2 of 10
Ozziemark
Having the same problem in MDT 2009
And i agree changing the layout scale in AMOPTIONS isn't a good solution.
Nobody ever came up with a proper solution?
Message 3 of 10
I been working with MDT6.0 for years - never had any problems.
Al
wrote in message news:6028778@discussion.autodesk.com...
Message 4 of 10
Ozziemark
So you mean that changing the overall scale of your dimstyle would directly update all your dimensions?
When placing new dimensions the OVERALL DIM SCALE setting (on the FIT-tab in DIMSTYLE) is being ignored and it just used the value 1. (Just to make clear, I am talking about the size of the dim text and arrows)
It does accept other changes, like color, arrow style, textheight etc. But it just ignores the overall scale setting...
After I typ in the command line : DIM, UP, ALL it does update though
From then it seems to follow all changes in DIMSTYLE settings box.
I am using my own personalised style. Which has been set in AM:STANDARDS under DIMENSION: SETTINGS
When doing a multi edit (AMDIMMEDIT) to change the "precision" on multiple dims, only the first selected dim updates. Additional text does get added to all of them...
It very well could be a specific setting but where to find it? I have already tried a lot of the settings in AM:options under AM;standards.
I am using the latest version of MDT (2009)
Thanks for any tips
Message 5 of 10
I still use MDT6 almost exclusively - even though I have most of the newer ones loaded. I have not experienced this problem. I set dimscale for drawings like the old days, 1/4 scale plots I draw things 1/1, make the insertion of the drafting format 4 times bigger, set dimscale to 4 and plot at 1/4. I do this in both model space and paper space, without ever seeing the forced setting you describe. Maybe you have something set in your dwt to change it to 1.
Message 6 of 10
Ozziemark
Yes you are probably right about some setting... But where to find it? Any suggestions?
Message 7 of 10
Ozziemark
Message 8 of 10
Ozziemark
Message 9 of 10
Ozziemark
Sorry for the triple reply, still getting used to the new forum interface. hehe
I keep getting an Error message after posting a reply, but message does get displayed apparently...
Interface looks a lot better by the way!!
Message 10 of 10
Did you ever get a fix? I have the same issue in MDT 2009
