Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
VBA - MDT 6 Error cteating a Mate constraint
0 REPLIES 0
Message 1 of 1
615 Views, 0 Replies
I have a problem. I want to create a Mate constraint between WorkPlane and McadPoint. I wrote this code:
Dim Patty As McadComponent
Set Patty=mcad.ActiveDocument.AssemblyMgr.RootDefinition.Children(0)
Dim Wplane As McadPlane, wpFeat As McadFeature,anyWP As McadPlane
For Each anyWP In Patty.definition.body.WorkPlanes
For Each wpFeat In anyWP.GetFeatures
If wpFeat.name Like "*Base#*" Or wpFeat.name Like "*base#*" Then
Set Wplane = anyWP: GoTo exF
Next
Next
exF:
Dim pt As McadPoint
Dim utM As McadUtility
Set ut = ThisDrawing.Application.GetInterfaceObject("mcad.Application").ActiveDocument.Utility
Dim Val As McadValue: Set Val = ut.CreateValue
' CODE '
Dim C2 As IMcadGeometry: Set C2 = Wplane
Dim dM1 As McadConstraintDescriptor: Set dM1 = ut.CreateConstraintDescriptor(mcCompMate)
dM1.Operand1 = pt: dM1.Operand1Orientation = mcRaw: dM1.Operand2 = C2: dM1.Operand2Orientation = mcRaw
dM1.Value = Val
Dim M1 As McadComponentConstraint: Set M1 = kt.AddConstraint(dM1)
When I try to create a new constraint I get an error: -2147196502(800461aa) "Generic Failure to executo operation with provide arguments". I have to select WorkPlane without Pick.
Please, help me!
Thanks!
Tags (3)
0 REPLIES 0
