Mechanical Desktop
Mechanical Desktop
Member
0 Kudos
Post 1 of 4
Unable to install content libraries for Autocad Mech 2010 64-bit on Windows 7
1908 Views, 3 Replies
05-18-2011 11:39 AM
Having an issue installing the concent libraries for Autocad Mechanical on a 64-bit Windows 7 machine.  During the install it give me this error (Error 1320. The specified path is too long: c:\documents and settings\all users).  If I go into configure the installation to modify the Content libraries under Autocad Mechanical 2010, it gives me this error (C:\Documents and Settings\All Users\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb).  Any ideas?
Tammy
Hi, Tammy
The default install location for content libraries on a Vista or Windows 7 OS machine is as follows
C:\Users\Public\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb
Can you try the above path during installation and verify if it works?
Please find attached snapshot.
Employee
4 Kudos
Post 2 of 4
Re: Unable to install content libraries for Autocad Mech 2010 64-bit on Windows
05-18-2011 05:02 PM in reply to: tforal
Tammy,
Since this Mechanical Desktop (MDT) Forum is not for AutoCAD Mechanical, I suggest that you post in the AutoCAD Mechanical Forum:
http://forums.autodesk.com/t5/AutoCAD-Mechanical/bd-p/39
or possibly better the Installation and Licensing Forum where the install experts hang out:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
I hope this helps,
Roger Mollon
Sr. Director, Software Development
Design, Lifecycle, & Simulation Product Group
Employee
37 Kudos
Post 3 of 4
05-18-2011 07:45 PM in reply to: tforal
Hi, Tammy
Sridhar Subramani
New Member
0 Kudos
Post 4 of 4
02-07-2013 06:37 AM in reply to: Sridhar-Autodesk
This problem is no longer a considered because it has been solved.There is away to fix this problem and the name of that software is Long Path Tool.I highly recommend it to you since I have already used it.
Manufacturing Community
