This is the file I am having a problem with. To reduce file size, I've removed the magazine housing, the magazine spring, the follower, the floor plate and I reduced the number of cartridges from thirty to four. The staggered double column of cartridges alone demonstrates the problem: when you try to section it using the "BBL VERT CNTR PLNE" and exclude both columns from sectioning, the program removes the projectiles from the cartridge cases of the left column.
Sincerely, Ralf Dieckmann
