Mike,
Type Ribbon at the command prompt and verify if ribbon tabs/panels appear. Else follow below steps.
Command wscurrent--> enter StructureCommand wscurrent-->Enter Mechanical
If you still have the issue;
On the command line, enter menuload and unload all the customization groups-->closeMenuload--> Select browse and load the acadM.CUI from acadm folder. ( C:\Documents and Settings\User login name\Application Data\Autodesk\AutoCAD Mechanical 2010\R18.0\enu\Acadm\)Click Load and then click CloseCommand wscurrent-->Enter Mechanical
Let me know if this helps.
Sridhar
Software QA Engineer
Autodesk, Inc.
Sridhar Subramani
Senior Product Owner
