Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Solids functionality?
16 REPLIES 16
Message 1 of 17
592 Views, 16 Replies
I figured out the subtract, and union etc. for solids.
But what if you do something and then later find out you do not want it
subtracted out?
Is there any way to easily "heal" a solid? Or is that were inventor starts
to shine?
Thanks!
16 REPLIES 16
Message 2 of 17
JDMather
Inventor and MDT do it the same way. Both are history based modelers.
The functionality is basically the same (except that MDT can't do parametric surfaces), the user interface is the main difference.
Post your file.
What release of MDT are you using?
Mech_desktop_200x_UserGuide.pdf
23 Chapters, approx. 764 pgs.
You paid for it already.
On your install disk.
Message 3 of 17
Are you using autocad or mdt commands?
Message 4 of 17
Well.... good question.
I am using mdt 2004DX
I am useing extrude, union, intersection, subtract... etc.
I do not know if they are acad or mdt commands....
I attached a file, the block in it has a notch cut out. This is the sort of
thing I would want to be able to undo, or remove the notch / or fill it back
in
easily....
Thanks for your help
"Jason Rhymes" wrote in message
news:5806229@discussion.autodesk.com...
Message 5 of 17
JDMather
>I am using extrude, union, intersection, subtract
Those are AutoCAD commands. You can download a free 30-day trial of AutoCAD 2008.
http://usa.autodesk.com/adsk/servlet/mform?id=9106363&siteID=123112
You might want to go to http://myfeedback.autodesk.com sign up for MDT Beta 2009. Code "Edison" (or was that the code for AutoCAD Mechanical - I can't remember - just search here if that isn't the correct code).
AutoCAD 2009 Beta code "Raptor"
Inventor 2009 Beta code "Tesla"
You can download Inventor LT for free from http://labs.atuodesk.com
Students can download Autodesk Inventor Professional 2008 for free from http://engineersrule.org
Message 6 of 17
What are the mdt commands for solids? I am not finding reference to other
commands in my help contents.
Robert Quinn
President RCM,Inc., Revcam, LLC, Heliforming Technologies
Tel: 586-336-1237
Fax: 586-336-1287
wrote in message news:5806297@discussion.autodesk.com...
2008.
remember).
Message 7 of 17
Try drawing your profile and using AMPROFILE to make a new part with the
profile then use AMEXTRUDE to extrude it. You can add more profiles to that
part and when using AMEXTRUDE on those profiles you have a choose on what it
will do to the original part. You can go back in the browser tree and edit
the profile/s at any time and use AMUPDATE to update the model.
Message 8 of 17
Can I immediately download those? I went there, and signed up last week.
But how do you download, I don't see the availability to do that?
2008.
remember).
Message 9 of 17
Sweet, I will give it a try.... I'll have to find that tree though (browser)
I have all that stuff turned off right now...
news:5806224@discussion.autodesk.com...
Message 10 of 17
JDMather
They are usually preceeded by "am" as amextrude.
Before you use the command you must create a sketch.
You then must "profile" the sketch (not required in Inventor).
Your help should list Help>MDT and Help AutoCAD.
Can you post a screen capture of your user interface?
Message 11 of 17
JDMather
Inventor LT can be downloaded immediately in N. America and Down Under.
Not sure about AutoCAD 2008 30-day trial outside U.S. In U.S. it can be downloaded immediately.
For the Betas you should get an email invitation back and can then download. I think a week is long enough might shoot Shaan Hurley at Autodesk an email. Although this close to the holidays might account for delay.
Message 12 of 17
Try AMBROWSER
Message 13 of 17
Well here is a screen shot. Not so easy method.
wrote in message news:5806330@discussion.autodesk.com...
Message 14 of 17
There's a separate help on the help pull down for MDT as JD mentioned
Message 15 of 17
I reloaded my MCADPP profile and there it was... Thanks!
news:5806422@discussion.autodesk.com...
Message 16 of 17
Thank you!
news:5806306@discussion.autodesk.com...
Try AMBROWSER
Message 17 of 17
hught
Bob, In v2006 MDT has a 'Replay' function enabling you to essentially replay the creation of a part. This also allows you to 'truncate' at any stage of the part creation and redo.
I am not sure if this was available in version 2004.
