Hi Kent,
Thanks for the information. Just now I tried the DVIEW. MSPACE, PSPACE etc. I was able to plot the perspective view with hidden lines etc. It worked. Thanks. If now I could get to generate a DXF file I would be nice, so it can go into a report, but I don't think the program allows it. Nor I can use the "export view" either! It is all greyed out.
Erich Koch
Kent Keller wrote:
> Erich
> I presume you are talking about a Dview perspective type of view? I don't know
> of any way to do it and have it stay thru updates etc. You can use the old
> Mview command to make a viewport, and then double click on the viewport, then
> enter Hide. I have never tired printing it or anything like that so I am not
> sure if it is even good enough for a one time shot.
> nope, I just tried making a dwf from it and the hidden lines showed up. Maybe
> playing with the plotting hidden line setting or ???
> Kent Keller
> Check out the Mechanical Desktop FAQ @
> http://webhome.idirect.com/~dfulford/
> "Erich Koch" wrote in message
> news:39BA2BED.D1F69A60@hotmail.com...
> > Hello Group,
> > I created a scene with a perspective view. Went to drawing and
> > generated a base view using the VIEW mode of the scene, but MDT will not
> > load the "perspective view", instead loads the ISO view prior to
> > creating the "perspective" view.
> > What am I doing wrong? Or is this not allowed? How do I create a
> > perspective view of the assembly?
> > Thanks,
> > Erich Koch
