Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
263 Views, 1 Reply
reduce file size
I have a Autocad dwg file that is exported from MDT view, how to reduce the the size? please help, thanks.
1 REPLY 1
Sridhar-Autodesk
You may use purge command to delete unused blocks, linetypes etc. to reduce the file size.
Sridhar
Sridhar Subramani
Senior Product Owner
