You could create a polygon with a high number of sides to simulate an arc.
Then run Image clip - new polygon and select the endpoints of the lines to create a new clipping polygon.
Attached is a quick example. I didn't create very many edges to approximate arc to save time.
Alternatively I guess I could have used the divide command to place a bunch of nodes for selection on an arc.
