IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Message 1 of 1
346 Views, 0 Replies
Plotter problem
When plotting in Mechanical Desktop 2008, plotter dialog box does not retain the plotter information. We have to manually select the plotter, sheet size and other plotting parameters each time we plot. Why does MD 2008 not retain this information. Plotter has been set-up via the "options" under Plot and Publish.
Windows XP Pro Service Pack 3, Panasonic DP-2330 Plotter using AutoDesk drivers, Mechanical Destop Version 2008.
Thanks.
0 REPLIES 0
