Mechanical Desktop
Mechanical Desktop
Member
0 Kudos
Post 1 of 1
parameterize a profiled blade using superposition of NACA profiles
457 Views, 0 Replies
05-10-2013 03:07 AM
Please, i want to modelize and parameterize a profiled blade using superposition of NACA profiles.
http://www.youtube.com/watch?v=sLm4hTVPF1c
To modelize and parameterize the profile of this blade using superposition of NACA profiles, i can import from Excel the points of the naca-profile direct in Inventor. But the problem is: I can not parametrize or change direct in Inventor the parameter of this curve. http://www.youtube.com/watch?v=hvUSAuplxZE
My challenge: i want to use a mathematical equation to generate the profile direct in Inventor. So i can select later the NACA-Model and select the preferred thickness, camber and camber location direct in Inventor to optimize the Blade.
http://walter.bislins.ch/work/index.asp?page=NACA-4+Profile
http://www.aerospaceweb.org/question/airfoils/q0041.shtml
I don't need the coordinates of the airfoil/NACA-profile, but i want to generate it direct in Inventor.
http://grabcad.com/questions/how-to-model-turbine-rotor-in-solidworks
Of course i want a program to set this NACA-Profil direct in Inventor. Probably use VBA-Code.
Can you tell me please how i can use VBA to set any curve in Inventor?
Do you know please, how i can use a mathematic equation to generate this point direct in Inventor?
How do you modelize a profiled Blade using NACA-Profile?
thank you verry much
Best Regards
pattedelapin84@yahoo.fr
Post to the Community
New Post
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
