IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Mechanical Desktop 2009 - Text disappears when MOVE command is used
4 REPLIES 4
752 Views, 4 Replies
We have recently up graded from MDT 2007 to 2009. Now when I open drawings created in the old format and attempt to move simple 2D text (or dim figures) they completely disappear.
They CAN be moved using the editing handles.
But if I select an entire view (non-parametric geometry on the LAYOUT tab), selecting text dims and all with a window (or single pick items with the pick box), and use the MOVE command, all entities move as expected except the text entities which simply disappear.
4 REPLIES 4
Sridhar-Autodesk
Can you attach a sample drawing file which has the issue or send it to sridharDOTsubramaniATautodeskDOTcom
Sridhar
Sridhar Subramani
Senior Product Owner
Thanks, Sridhar.
We have since discovered that after being moved the text can be seen by doing a REGEN, but that is time-consuming, too.
Scott
Sridhar-Autodesk
Hi Scott,
I could not reproduce the issue on MDT 2009 SP3. Can you insall SP3 from the following link and verify the issue again if its not installed?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019#section25
Sridhar
Sridhar Subramani
in reply to: Sridhar-Autodesk
Was this ever resolved?  Did updating to SP3 fix this issue?  I am having the same problem right now with the text disappearing after moving it to a new location.
Any help or insight would be greatly appreciated.
Wayne
