Hi Chris,
Can you post the drawing to us to investigate?
Meanwhile, please try the following steps to turn off the arc extension
line:
1) Select the radial dimension
2) Right mouse click & select "Properties"
3) In the properties palette under "Lines & Arrows", turn "Ext line" to
Off.
Vincent Yeap
Software Developer
Manufacturing Solutions Division
Autodesk, Inc.
wrote in message news:5588898@discussion.autodesk.com...
Is there anyway to turn off the arc extension line added when I dimension a
radius? This new ability sounds great, but it produces undesired results
when used in MDT2008. It generates a arc extension line with the start
point "out in space" from the actual arc, and it always shows a arc
extension line even when the dimension is placed on the actual arc.
Please refer to the attached image for an example.
Chris Hutchinson
Duke Energy
Charlotte, NC
